-=> SFP 3.1 a -=> SFP 3.1 a -=> SFP 3.1 a -=> SFP 3.1 a
darolek
Post by darolek »
What about EQ section in STM-2448 mixer ?
On SFP 3.1 don't work midi control of knobs (gain, Q, freq).
Is in new version fixed this feature ?
<font size=-1>[ This Message was edited by: darolek on 2002-05-29 15:53 ]</font>
kimgr
Post by kimgr »
As far as I know you where never able to control the mixer comp/eq with midi, right back to the first version of the current mixers ? (The Scope/SP mixer).
Kim.
darolek
Post by darolek »
Comp section in STM 2448 (on SFP 3.1) is controllable via midi - eq not ! Check yourself Kim :wink:
kimgr
Post by kimgr »
You're right. And when you're right, you're right... :wink:
Kim.
ernest@303.nu
Post by ernest@303.nu »
I'm really sorry there's still no EQ automation on that mixer :sad: :sad: :sad:
There's really no reason to leave this feature out, as the BigMixer does this without any problem, and even offers "unlimited" number of bands on each EQ. :smile: So the CreamWare engine should be capable of that task.
It's amazing what you can do with EQ's flying around.... I really Like the PulsarMixer (and what you're talking about is probably it's SFP3.1 re-incarnation??? I'm still on 3.01a) but lately I choose the BigMixer more often because of the EQ automation.
borg
Post by borg »
you can copy both pulsar and big mixer into sfp 3.1
bee sure to have your reg numbers ready though.
andy
the lunatics are in the hall
ernest@303.nu
will surely do so when I upgrade to 3.1a....
Just waiting for the solved-bug-reports on this forum for 3.1a :smile:
Until then I'll keep smiling to my Win98SE screen without the LiveBar....
But anyone must agree that it's really strange that only the Good'Ol'BigMixer offers EQ-automation. :eek:
I guess that's bad luck then for new CW-users who only get the 3.1 devices.....
<font size=-1>[ This Message was edited by: ernest@303.nu on 2002-05-30 05:20 ]</font>
Well, don't have any of the 4 eq points set on that channel (i noticed dsp usage rises) and disable the channel eq, then use an insert. Should automate fine.
I too would love if everything were perfect for me, but after 2.5 years of instability on dual cpu systems, I can put up with minor workarounds now that EVERYTHING WORKS.
Now if only I could avoid those pesky DSP Capacity Reached msgs I've been getting lately :wink:
ernest@303.nu
Yeah, user-definable "DSP limit"-messages would be really fun
Where's the .ini to edit them?
:smile:
darolek
Post by darolek »
STS-2000P works in 64-voice polyphony now ! Wow :grin:
Great job Creamware !!!
Noctulius
Post by Noctulius »
Just repeating my own post in "Announcements" section (quite an inapropriate place for it I guess):
Erm... Sorry for interrupting you guys, but I'm about 24-bit Wave again (obsessed freak am I?). In WinXP of course.
Well, WaveLab does not playback at 24-bit and something's wrong with the recording. But maybe it's up to this particular software only? Any Sonar users out there? Anyone who would try 24-bit rec/playback in Sonar? Please...
darolek
Post by darolek »
Yeah - I confirm this fact - 24bit wave drivers still dont'n work under XP correctly :sad:
WaveLab don't playback on 24/24alt/20-bits and OS applications produce something like short channel-delay.
CAPO
Post by CAPO »
Hmm... Using Cool Edit Pro 2 and Samplitude I am able to record using the 24 bit wave drivers.... and I have XP
Maybe it is somthing else...
I do know, however that soundforge F***s up my audio files after I save them no matter what (when I use the 24 bit driver)... I recorded a bass line and when I saved it it turrned into pure static and scared the dailights out of me (when I hit playback and was bombarded with white noise at deffining levels).
Dont know what made this happen... But I can record find in Samplitude and Cool Edit Pro 2
CAPO
sandrob
Post by sandrob »
i can record 24bit in wavelab useing 24bit-alt, but can't do 24bit playback.
i have wavelab 3.0 but i think that 4.0 can use asio scope driver - i'm not sure?
if yes, than can be one solution:
in custom work with cubase use 24bit-alt recording and 16bit playback and if you realy need 24bit playback than use asio scope for mastering when cubase is not active.
not comfortable, but...
sandrob
Post by sandrob »
i just try wavelab 4.0 for the first time. now is possible to do 24bit playback! 24bit recordings is possible with 24bit-alt options!
so, everything works!! we have 24bit playback and recording in wavelab and sfp is ok!
my friend told me it's "normal" and he have same seting with rme.
Noctulius
Post by Noctulius »
Guys!
As I said, I know this happens in WaveLab, but anything about Sonar? Please...
If it does work in Samplitude or CoolEdit, there's a difference, isn't it? So please SONAR tests anyone?
sandrob
Post by sandrob »
i forgot to say: this is under wdm drivers. :smile:
