Hi!Just many little questions..
I've got a pulsar1 and I just bought a luna2 with adat/z-link card expansion with 2 2496 boxes.Those are my questions:a)Is it true that to make use of all dsps (4+3) I must run pulsar software and not luna software?..b)and when will be avaible xtc software for all pulsar users the xtc software will "see" all dsps of both cards?c)xtc software will be avaible for pulsar 1 users too?
d)After I copied the registration line in both scope drivers what difference there will be between pulsar and luna software?
e)Using pulsar 1 and luna there will be sync problems between the 2 cards?(setting pulsar as master 2496 converters will detect the sync?)
Thanx a lot!!!!
LUNA and PULSAR1
pulsar software is a step up from the Luna software, yes. I think you can only use the Luna devices + free devices if you're running the Luna software.
With the Pulsar software, you can run all the Pulsar devices, plus everything else, and you get to load all Luna devices inside the pulsar environment.
Think of the Luna software as a subset of the Pulsar software, and Pulsar software as a subset of Scope
lifechanger
