Is Two ASIO Source Modules Possible?
braincell
Post by braincell »
I want to run Logic Audio 5 and FruityLoops with SFP. Is it possible to use two ASIO modules with them? I noticed they can't share one.
remixme
Post by remixme »
Nope it aint possible, not unless you know of a way of making logic not grabbing hold of asio ports 1&2.
My advice is to wait a fortnight till fruityloops 3.5 comes out and then you will be able to use it as a VSTi
Problem solved.
Add life to your days, not days to your life.
kimgr
Post by kimgr »
...Or use two Asio cards.
I use Scope for Logic and Oasys for Reaktor.
Kim.
braincell
Post by braincell »
Ha I have no more slots anyway. I have the Luna, The Pular and an SRB plus a Sync plate which makes a 4rth slot unusable even though it does not use a slot.
use a wave driver for fruity.it'll stream perfectly.
