CAn you disable the I/O's on a Pulsar II
milko
Post by milko »
I have two pulsar cards (Pulsar II and XTC) is it possible to disable the I/O's on the Pulsar II card so when I linked them together It is just one big XTC card.
Reason: I want to use the I/O's from Delta 1010 and I can't sync them up.
scopeman
Post by scopeman »
Pulsar is working better, when used as asio device with ios.
When you select the asio driver from the Delta 1010, you can use Pulsar in XTC mode, th ios are disabled.
A better idea is to sell the Delta and buy some ADAT io like the fostex. So your are more flexible. The best thing would be to use Pulsar under the new SFP Software.
yeah,the delta's pretty sad......
