The SFP bug list.
remixme
Post by remixme »
Ok right now I don't want to spoil everyones fun, but no one expects a release to be bug free, although I think creamware have done a GOOD JOB on scope. If we compile a list of common confirmed bugs creamware can fix it quicker.
Also people thinking about moving to sfp can look and make an informed decision
So if you have any problems, post here keeping this format.
First List the problem:
System setup (cpu/chipset/os/cards):
State whether this has been confirmed by a different user/or different setup:
Add life to your days, not days to your life.
remixme
Post by remixme »
Like this,
Problem: Removing multiple inputs or output modules in routing window causes error msgs, and doesn't remove the modules.
Setup: Athlonxp/via/winxp/pulsar1
Confirmed: Yes by me, originally found by musquash (what setup are you using?)
Note to atomic in regards to below post, have you tried removing all in's and out's leaving some behing ie two. This is what causes error I believe.
<font size=-1>[ This Message was edited by: remixme on 2002-05-08 14:45 ]</font>
<font size=-1>[ This Message was edited by: remixme on 2002-05-09 08:30 ]</font>
i'm sorry if i spoil the topic, it is a very good idea. but it works here :grin:
setup: XPpro/815i dual PIII
Grok
Post by Grok »
since I've installed SFP I have a little "echo" delay on Windows System Sounds.
I've made a new default project as I was used before, with 3.01.
Do you have an idea of what it is?
remixme
Post by remixme »
The words keep this format sailed right over some body's head :wink: But if not remedied it goes down as a bug.
Does disabled hardware acceleration of sound solve the problem? Could it be a feed back loop, try disconnectings things in your startup project and see if it goes away.
If anyone else has this problem post it
On 2002-05-08 14:32, Grok wrote:
...I have a little "echo" delay on Windows System Sounds.
First tweak: turn off the sounds :grin:
sorry, i don't know the solution. instead of 'making a project like before', try connecting WAV Source to HW Dest directly, just for troubleshooting. Eliminate stuff.
Is it only on the first boot sound? Did you make a 'large' boot project?
<font size=-1>[ This Message was edited by: at0mic on 2002-05-08 14:53 ]</font>
paulrmartin
Post by paulrmartin »
Could it be about latency being put at its longest by default?
Kamurah
Post by Kamurah »
Problems:
1. Windows have bitmap garbage around them. Only solution is to hide window / show window. This has to be repeated for each new window. (It has to be repeated EVERY time I go into a different subset on STS 3000!)
2. Live bar options do not stay active, must move cursor to another option then back to previous.
3. Some older devices do not work (three-o-three). Just won't load at all.
4. Some devices show up improperly (Inferno). Show / hide does not fix this.
5. Auto connect does not work with older mixers (i.e. Pulsarmixer)
6 Some presets won't load.
7. Live bar sub regions are not labelled....have to put curser there and wait for popup in order to understand what the function is.
System:
Macintosh G4 500mhz
768mb RAM
OS 9.0.4
OMS 2.3.8
20 GIG HD (System)
60 GIG HD (Audio)
Pulsar II card
SFP 3.1
Bugs unconfirmed with other users, but I reported them to Paul at Tech support via phone, and got an affirmative.
<font size=-1>[ This Message was edited by: Kamurah on 2002-05-08 15:48 ]</font>
kensuguro
Post by kensuguro »
Live bar is always on top.
Typing in polyphony causes crash.. not sure what the rule is tho. It seems to be a textbox issue?? Oh when will they get the text boxes right.. :sad: But it works just fine with some synths. ehh? Now it works.. oh no, it crashed.
By the way, I seem to have found the "right" way of double clicking the text fields.. you can't double click without moving the mouse. You have to move a pixel or two for the second click. Double clicking at the exact same position won't work. But you can't move too far away from the first click either. It's kind of wierd.
Dragging livebar contents has a strange limit. You can drag the icon up, but you can never drag it down to the lowest empty area. Not much of a problem, but I can't understand why such a problem would exist in the first place. hmmm...
setup:
p4-2ghz, p4te, XP Pro, Pulsar II
<font size=-1>[ This Message was edited by: kensuguro on 2002-05-08 17:12 ]</font>
Neutron
Post by Neutron »
virtual MIDI LEDS on some synth devices do not light (even creamware ones)
vectron player loaded with no preset and made no sound.(in combination with light not working i thought it was a big problem!)
P4 PC using pulsar midi in from keyboard.
2 creamware cards.
EarlyFirst
Post by EarlyFirst »
LiveBar is only ontop if the _ontop_ button is pressed :wink:
anyone press the Scope icon yet?
How about the esc during loading of a device?
303 and inferno ok for me.(no burning flame tho :wink: )
no windows echo either.
looks pretty good.
p4/intel d850mvl/98se lite/pulsar1,2x pulsar1 srb
<font size=-1>[ This Message was edited by: garyb on 2002-05-08 23:05 ]</font>
bosone
Post by bosone »
i want a function to hide only the scope live bar... and keeping on screen only routing window and file browser...
beside this: i tried to rename the "favourites" folders and SFP crashed...
kensuguro
Post by kensuguro »
yeah.. it definitely still has that text box bug for sure. I just lost another project.. boo hoo.. 2 days and 2 projects lost for the same reason isn't too good. :sad:
glance
Post by glance »
You can have SFP and Pulsar 3 running on the same machine with SFP drivers. Atr least that's the case here with winXP etc. SFP intsalled in a new "Creamware New Folder".
So I have S¨FP Intsalled, but if I want i can still work in the prezvious pulsar version with no problem.
I hope it helps
EarlyFirst
bosone
hit the scope icon on the livebar :wink:
junklight
Post by junklight »
Haven't fully investigated this but:
I tried to route my SBLive through the creamware (yeah, yeah I know but the cd player is connected to it and its useful for the very occasional game). I dropped in the Sound Source module and it had a list of sound sources (including oddly two creamware ones!). I could not select ANY of the sample rates for the SBLive without being told it didn't support them - no sound through it either.
Its not a show stopper though
cheers
mark
__________________________________________
junklight - dark experimental electronics
http://www.junklight.com
bosone
Post by bosone »
On 2002-05-09 02:08, EarlyFirst wrote:
bosone
this simply reduce the size... but it always stays on top!
kensuguro
Post by kensuguro »
same here. oh well, nothing I can't live with. Probably not that big of a hassle to fix too so it should be fixed in the next version.
darolek
Post by darolek »
Problems:
1) 'Sequencer Remote' still (vs Pulsar 2.xx/3.0x) send-out nothing while you hit 'REC button'.
2) Many Modular 2 patches on load get error "Cannot find DLL or script".
3) STS-3000 wrong displays 'Free memory' size after load next programs.
Setup:
TUSL2-C/PIII-1GHz/WinXP Pro
Matrox G-450/Pulsar 2
SFP 3.1 (upgrade in separate folder)
<font size=-1>[ This Message was edited by: darolek on 2002-05-09 05:11 ]</font>
