Please be sure, not to use more than 4 cards in the same computer. Opposite to the P4 chipsets, the athlon chipsets do handle a maximum amount of 4 IRQ´s -  that means you reached the maximum by using 4 cards, unless the drivers are so well programmed that they alllow 200 % irq sharing, which is almost not the case.
<font size=-1>[ This Message was edited by: zer on 2002-04-24 03:17 ]</font>
						note for Athlon users
four PCI cards or four creamware's?
							I'm still seeing new things in life.
<p><a href="http://mp3.com/dxl">www.mp3.com/dxl</a></p>
Any pci card I think.  You can 'create' more IRQ's by disabling USB, serial and paralel ports,...  anyhting you don't use, turn it of
An S/TDM cable, which is used to interconnect different CW cards, has only 3 connections. You can install maximum 3 CW cards in one computer.
<font size=-1>[ This Message was edited by: at0mic on 2002-04-24 09:32 ]</font>
 my mistake
 my mistake
