<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/pro ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Related To: Cubase<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar 3.x<BR> _____________________________________<BR><BR> OK the project layout
In1>8=Asio2 16bit source
In5>13=STS 3000
In14 =Analog source
Channels 5and14 are stereo as are all the ASIO input channels..
Channels 5-14 goto bus1/2
the rest of the sts goes to the rest of the busses...So while your recording if you only use the L/R out of the STS change the Buss for the Analog source to 3/4
this way you don't overlap.....
The STS inputs that are mono are hard panned so you can record to each side of the buss or in stereo.
						revised ASIO wthSTS3000
- EarlyFirst
