Asio
Tony B
Post by Tony B »
Asio
Disk too slow or system overload(10010) continue.
System: Win 98 SE; WD eide 40g HD; WD ide 20g HD; 512 MB memory; Luna11; Logic 4.81;
intel 815 Chipset Mobo; Help!!!!!!!!!!!. It is happening too often.
dma enabled?
subhuman
Post by subhuman »
What garyb said + Chipset drivers installed?
Tony B
Post by Tony B »
When I installed the Intel ATA Storage Drivers(any version) I do not see the DMA check box but when it is not installed the check box is there. I did not reinstall it in order to have that option. DMA is enabled.
Any version of the Intel 815 Chipset drivers I use the same thing happens. The problem comes up more often as the amount of tracks increase. One or two tracks plays fine but as I record more there is this thing.
Tony B
Post by Tony B »
I have reinstalled the ATA storage drivers version 6.20, loaded 8 wave tracks, let the system play for about 30 minutes nonstop,no problem but I have lost the DMA check box.
kimgr
Post by kimgr »
You don't NEED the DMA-checkbox when you have the ATA storage drivers installed, as those drivers automatically enables DMA.
In Start->Programs->Intel ATA... you have a program (called "Companion" or something like that) where you can check the status of the drivers and DMA modes.
Kim.
Tony B
Post by Tony B »
Thanks for the help. You guys are great. A fella could come here knowing nothing and learn something.
subhuman
Post by subhuman »
BTW the DMA checkbox not showing is like, in the readme file for the IAA drivers, that's how we learned it ourselves... :wink:
kimgr
Post by kimgr »
WHAT???
You expect people to actually READ the readme files ???
What have you been smoking today, SubMann ???
:wink: Kim.
subhuman
Post by subhuman »
Heaven forbid! :wink:
