A workmate has his car tuned and he's put a mega hifi in it. He's in a tuning club, they do demonstrations, ralleys and dB drags. In a dB drag, the one with the most dB in his car is the winner.
Has anyone experience with the CD's they use for that? As they seem very expensive, he asked me to do a simple tune to test his installation.
So now I have a couple of questions/remarks.
-> I guess they measure the dB in peak value?
-> How can I create the highest dB peaks in his sub woofer? Should I read the info on the sub, about it's frequency response etc.? How should I interpret it?
-> Any particular synthesis I should prefer over another?
I'm Manuel form Barcelona and I know nothing. Anyone experience with this or can someone explain me how to get him the highest possible dB with his setup?
Yes, not all people enjoy music the same way we do
edit
Hi Paul,
I'm still thinking of a creative way to spend my 1000th post. Not easy, I'll have only one. Becoming Guru then will be to much for me. I hope people realise it's the amount of posts which makes the Guru, it's only a vague reflection of the real contributions. I do not consider myself Guru at all, I just like to bring up idea's and learn myself.
Ken,
The mic is placed inside the car, in the center against the windscreen. He says he'd only use his sub (which is in the trunk). You point out a good reason for him to leave his mids and tweeters on: higher frequency, higher dB. Wasn't it low freq's producing more energy? Or is that in db(A)? I'll have to check what a dB meter measures. I know the cops use dB(A) here.
Also, you confirmed my idea of using sine waves. Hey but if you clip those, what kind of clips do you suggest? Clipping like in reaching 'more than 0dB' or clipping like 'inverting the signal when on max amplitude'. Both signals will produce about the same audible clip, although +0dB clip may eventually make a square of the sine.
Subhuman,
Thanks for the link!
atom.
<font size=-1>[ This Message was edited by: at0mic on 2002-04-20 19:59 ]</font>
<font size=-1>[ This Message was edited by: at0mic on 2002-04-21 05:16 ]</font>
