Recording to hard disk into Logic, using Pulsar 2 synths, He
flux
Would anyone be kind enough to help someone more into the music than the technical side (hence my difficulties). I have written some songs using logic with some audio loops, with pulsar synths over the top. I have asked before here, but nobody helped me. I now want to record the synths and audio loop into one stereo wav file through logic, so I can then burn it to cd. Please help! Maybe someone also has a project set up for this they could send me? [email protected] Thanx
krass
Use ASIO drivers in logic, create extra "ins" on your ASIO driver module that goes into Logic.
Route the output of the synths into Logic, arm your tracks, and record the 2 synths on separate tracks...
Then, together with all your other audio, perform a mixdown.
This will create a stereo mix of everything.
I'm not a Logic user, so I wouldn't be able to tell you precisely how to do it, but this is about how it should work...
Good luck recording!
Greetz,
KrasS
Greetz,
KrasS
