Is there an optical spdif in pulsar 2 input
can the adat inputs be used so?
Optical Spdif
ernest@303.nu
select 'opt. S/P-DIF' in the 'View -> Samplerate Settings' menu and there you go!
But for some reason, on my Pulsar2/3.01 the 'opt SP-DIF source' (from the Hardware IOs menu) doesn't work.... the optical s/p-dif source will play fine through the s/pdif coax I/O though, but as you'd expect things go wrong when simultaniously connecting an optical and a coaxial source. See also this topic on PlanetZ.
I'd really like to know if anyone managed to use an optical source through it's appropriate IO in the Pulsar 3.01 environment???
[edit] typo [/edit]
<font size=-1>[ This Message was edited by: ernest@303.nu on 2002-04-10 05:29 ]</font>
[edit] typo [/edit]
