Another PC noise trick
My DAW PC produced a lot of rattles and buzzes, which were amplified by the case (a tall tower with steel sides). I will add some foam or other deadening material to the inside of the side panels, as suggested elsewhere here, but in fact, I have the side panels off fequently as I am often in there fiddling.
For audio tracking, close it up, but otherwise, the huming and rattling are bothersome. I thried this:
I cut little circles of bicycle tire inner tube and drilled holes through the centers. Using longer than normal mounting screws,
I put a a little rubber circle between the side of each drive (CD and HDD) and the PC case mounting bracket. I also put little plastic washers under the screw heads, and thus pretty much eliminated most of the metal-to-metal contact between the drives and the case. Same for the power supply/fan unit.
This made quite a difference, so much that I wished I had done a little before/after db metering to measure the improvement.
Also, on the front panel, the little plastic covers in my case covering unused dives bays were a source of buzzes. A couple of tiny squirts of silicon caulking (like for small bathroom countertop repairs) into the gaps quieted them right down. It only took a few drops and I'm sure I'll be able to prise them free easliy enough if I need to later.
				algorhythm
only problem is that by eliminating the metal-metal contact on drives, the heat dissipating surface area is greatly reduced, which means that your hard drive will tend to run hotter, and therefore not last as long (think of your whole case as a heat sink).  An appropriately placed fan or ductwork can eliminate this problem.  Perhaps do a before/after temperature test on the HDD?
						Good tips.......better still (but more costly) is this case.....www.calmpc.com
I've just ordered one for my control room, I'll post my findings when I get it set up and running (hopefully next weekend...around the 13th)
hahah yes a nice powerful FAN ought to solve the overheating caused by QUIETING your computerOn 2002-04-05 06:09, algorhythm wrote:
seriously though, you might try isolating the whole drive cage from the rest of the case instead, then the drive cage is still heatsinking the drives, but the vibration is kept from the case and its drum like side panels.
A good point Algorhythm, but I did actually think about this (though I didn't take any measurement)
Just feeling by hand before making this change, I found very little heat on the outside of the drive rack brackets a small distance above and below where the drives are mounted. By doing this I no doubt lost some bracket surface area for heat dispersion, though I suspect the finned top plates on the HDDs are the most important part.
Life's all tradeoffs, I guess. Before this, sometimes the drives would set the whole bloody case into a nasty, loud LFO reso thing (whah - whah - whah - whah), and I'd have to press my hand to the top of the case to dampen it down. That's gone now.
atomic - maybe you friend should use a SCSI CDRW. SCSI works over a couple of metres, doesn't it?
Anyway, for the cheapo bedroom, obsessed amateur studio like mine, this trick is work a couple of hours, provided cooling isn't compromised too much.
<font size=-1>[ This Message was edited by: dblbass on 2002-04-05 20:52 ]</font>
Here's a topic about cooling.
How I cooled and silenced my computer:
-I glued some (5mm, but heavy) rubber/foam to the case, about everywhere but one the vent holes
-I took insulation tape and put it on the edges where the case hits the frame/box.
-Made a sandwich for my drives, w 2 thick aluminum plates, which stick out the disks. Then I filled up the sandwich sides w thicker foam.
-On the center frame -between my motherboard and power supply on the rear and between cd/hd bay on front- I put a plate. Made a hole in the plate to insert a fan. This causes a strong flow from the bottom to the top of the pc. The fan is not close to air in/outlet which causes less noise again. If I had not put the extra fan in, my pc would run too hot with all the isolation foam.
About SCSI drives: my experience is that those are quite noisy. Here's my friend's site (the one who moved his pc to another room for less noise).
at0mic.
<font size=-1>[ This Message was edited by: at0mic on 2002-04-07 01:46 ]</font>
at0mic.
				John Henric
Check out this hd suspension/damping solution. Too simple or what? I think it can be replicated quite easily by a 'layman'.
http://www.whynoi.se/shop/product.asp?intProdID=48
http://www.whynoi.se/shop/productsByCat ... E4ngningar
I made a post here about noise that may be of interest
http://www.planetz.com/forums/viewtopic ... forum=19&0
http://www.quietpc.com/powersnooze.php
i installed that stuff in my pc to quiet it.
the temperature is the same as before, but the quieting wasnt all that noticeable. It did reduce the side-panels singing along with the hard disks completely, but the fan noise level seems to be the same still.
(i should just get a quieter cpu fan maybe)
i have also thought about buying a 2nd set of those mats and use them in a iso-box that i can build myself.
I have fitted my PC out with components from Quit PC.
I have installed:
Silent power supply
one 8" rear fan
P4 (478) silent heatsink and fan
two silent drives for both HD's
I also lined the whole case with accoustic dampening material normally used for cars with big stereo's
The noise is now minimal, I can't even hear the computer at all over the road noise (which is minimal).
I totally recomend doing this to your computer.
Laterz
							I have installed:
Silent power supply
one 8" rear fan
Laterz
martin granger
						What should be done (by some genius) is to place a ultrahigh fidelity mic that takes the sound of the noisy PC, then refeed it over some kind of studio monitor, in the correct phase to null the noise. Phase opposition for real time sound cancellation.
It's science fiction (eventhough it is used in long courrier planes) but i'm interested in anything in that field if you have links...
just an idea, i know it's not very doable. .
Myself I use the "put it in another room" solution : cheapest, very eficient in home studios. It's also used in studios who can afford expensive boxes to isolate the noises.
<font size=-1>[ This Message was edited by: spacef on 2002-05-31 05:59 ]</font>
It will not work very well because the sound sources are in different places. so the phase of the waves at each frequency has to be constantly calculated. even then if you move your head 6 inches some frequencies will get twice as loud because of standing waves.and reflections all over the room.
someone had the idea for outside noise though. get a "sound bug" and put it on the window. have a mic outside the window.
window moves in opposite direction to incoming sound and cancels some of it out.
works better with a window because the sound is all coming from the same direction.
that's why i've chosen to put the computer in the kitchen
For the speakers that cancel noise, i think it's possible with a "super surround" (hundreds of speakers everywhere in your room). (imagine all your walls, floor, cellars is a speaker).
Curently it's absolutely true that it works only as you said, but may be that's not due to a mathematical impossibility to do it, but to the current sound input/output technology which makes this not doable.
I think latency is also a problem, at least nowadays.
The computer in the kitchen is better for the moment...
<font size=-1>[ This Message was edited by: spacef on 2002-05-31 08:02 ]</font>
