Multiple Akai sample programs can be selected in the file browser using the control key, then copy in the usual manner. If you need to copy multiple sample programs in a more unordered way, you can create a directory - and temporararily replace the path to the Devices folder with the name of the directory that you just created. This way you can easily toggle between the CD drive and the location you want copy to, using the devices/samples toggle button.
Thanks to <A HREF="mailto:Marc_de_Ruiter@randstad.nl">Marc de Ruiter</A>.
						Shortcut for copying AKAI samples from CD to hard disk
- John Cooper
- Moderator
thanks to your reply
but as i alredy said ,
when i copy program or folder and try to paste in another folder i ve choosed ,there is nothing to paste?
that is my problem
i work with win98,pulsar 1
same result with pulsar file browser
i copy something and than press paste i can hear something is goin on but i cant find copyed files on HD
roger?
thanks to yo
that is my problem
roger?
thanks to yo
I've had this problem before. I don't think that the question is being asked correctly. When I place an Akai CD into my CD-ROM drive and I wish to copy those files onto the hard-drive, what is the most usable way for me to accomplish this and have them more Pulsar Friendly?
1. The Pulsar format although similar to the Akai Format is slightly different, especially in the way that the hard drive reads it. A Pulsar file doesn't need to be formatted on an Akai formatted disk.
2. The object is to convert all the files on the the Akai disk to a set of files on the hard disk in Pulsar Format and have them loadable and readable and fast.
3. This process is called a batch conversion. It will take all the files on a CD and make them into files that are friendly on your hard drive.
4. Use this program to make it happen.
http://www.chickensys.com/translator/
I've taken a broad based sample library of Akai, Kurzweil and EMU formatted samples and dumped them all into Pulsar friendly formats on the hard drive. You can too.
Akai CD extract:
http://www.cdxtract.com/
