Pulsar II 3.01 does not save my presets
Presets are not saved in a project.
3.01 devices: You should save the presets in the Preset List. Export them to a .pre file. If the file is in your ..Pulsar3presets folder and has the same name as the device, it will load automatically next time. If you've changed/added presets, Pulsar OS will ask you if you wanna save the list (overwrite or new file option too) whenever you delete the device or close the project.
2.04 devices: can be saved within the device. Or externally. Both from the Preset List too.
you are right sandrob. When I load a new project I work with the Big Mixer. The parameters like Volume, pan etc. will always be there after saving the project. But the parameters of the inserts are gone. Have I really to save every insert parameter change seperatly?
Many thanks for your replies
obrut
obrut
King of Snake
or get the Propack with the PulsarMixer which works allright. (although midi implementation is less than complete and there seems to be problem that compressor sidechain settings aren't saved when saving the project, but maybe I should just save a seperate comp. preset....
I've only just started working with Pulsarmixer and it's a bit hard for someone who's never worked with anything more comlicated than dynamixer
