external effects
korgano
Post by korgano »
how to connect an external FX with
pulsar 1 SW 3.0 and use it in project
borg
Post by borg »
what are your i/o options? do you have just the pulsar card, or do you have another sound card? is there an ad/da convertor in your setup? what connections does your external fx box have?
in general:
-with mixer: in pulsar connect aux send to your preferred audio output (analog/spdif/adat?), from phisical output to your fx in, from fx out to desired input for pulsar, then in your pulsar project from whatever source to return, or a channel if you prefer.
-direct: source to a audio dest. module, phisical output>fx in, fx out> phisical in, audio source module>wherever you want your processed audio to go into.
hope this makes sense,... so many possibilities, and such a little amount of information you give us :wink:
andy
the lunatics are in the hall
korgano
Post by korgano »
thanx
here a bit more info:
i would like to buy
lexicon mpx-1, or mpx 500
still didnt decide.
on pulsar1 have adat optical I/O and SPDI/F
connections.
what about switchin between Slave and Master?
no spdif loops w/pulsar 1
subhuman
Post by subhuman »
I am adding an A16 Ultra to my setup specifically as an effects send/return device.
I have 8 channels going out of my digital mixer into Pulsar (Aux & bus sends), where I can freely patch the incoming audio into any of my external or Creamware effects, and back out with zero latency. This is going to rule!!
