luna 2 and virtual synth
dj shadow
Post by dj shadow »
hi there i've bought luna 2 since few and i've lot of problem with virtual synth and ùwith others too
i've a p4b266
a pentium 4 1.7GHz
256 ddr ram Kingston
and use windows 98
the problem is that when i play something like b4 or reaktor when i set the ulli and then i want to set the latency from the panel of the synth the audio card get blocked and i've to shut down the computer
also hear lot of pop in the windows start sound
the if i go in multimedia from control pannel
sometimes i find creamware dsp(play and rec)
and sometime i find Luna (play and rec)
GIgastudio wont work too,it doesnt let me load sound on the midi control surface.....
i've teh version 3.01
and i've used the elupo*.inf driver
please Help me
algorhythm
Post by algorhythm »
use the ASIO drivers in your luna project, not wave drivers. after loading the asio drivers, then in your VST app, select that driver. you should get low latency then - 4ms or so . . .
can't help ya on the giga
:grin:
dj shadow
Post by dj shadow »
oh thanks.....since i'm a dork
could you please tell me excatly how i should make the project that you said.....
i'd use sonar or cubase....
please
w_ellis
Post by w_ellis »
In the Luna II manual, in the section called
'Integrating Luna and Your Recording Software' (pages 16-29), there is a pretty well written description of how to set up Cubase and Luna to work together. I think this is quite a good place to start.
I think that there are some posts about using Sonar with Luna/Pulsar about. I'd recommend doing a search on 'Sonar' in this forum.
Cheers,
Will
