Hello everybody ! How is possible to record my Cubase proj in 96k ? I have loops and voice in 44k and i want to record them into a separate track in 96K to apply for mastering. I've tried to change samplerate setting, but then i cannot hear my proj anymore, and if i try to rec in 96k when i listebn it (turning back to 44) go to double speed. What is the right procedure ? Thanks in advance
Bye
44k rec in 96k......
Yup, if you wanna import 'different samplerate from clock' you'll have to convert, some programs do it for you (like Cakewalk does make new wavs per song/import).
Sampledepth changing during processing is normal, but the rate is better not changed. I think you better keep it in 44.1kHz. Cos you'll have to down-convert after mastering again. What a hassle
