(1) Drum sounds...? and (2) a thing about Reason
Ofcourse their is the eds8i synth but I'm looking for a 'big'drumcopmuter. Does this excist for Pulsar?
Before I bought a Pulsar II I used Reason and their was a really nice drumcomputer inside. Easy to use and lots of sounds.
Is it wise to use Reason next to Pulsar to use, for exapmle, the drumcomputer (especially because I own Reason allready)?
And if it is, how do I connect Reason to Cubase/Pulsar. Does Reason use the Pulsar card?
This are several questions which I hope someone can answer.
Thanks.
Thanks.
Afdeling houdbaar... kassa 2 alstublieft (don't know how to say that in English)
some links... 1. stephen hummel's drumvox (great devices) 2. sds (excellent and free) 3/4. modular patches (there are some more, i think.)
http://www.track0.com/wavelength/wave%20frameset.htm
http://www.planetz.com/forums/viewtopic ... 2&forum=16
http://www.planetz.com/forums/viewtopic ... forum=15&0
andy
the lunatics are in the hall
algorhythm
check out my "lo-fi beat box" mod2 patch extremely dirty:
[ { ( - algorhythm - ) } ] /
<font size=-1>[ This Message was edited by: algorhythm on 2002-03-18 19:42 ]</font>
yeh its easy to use reason with pulsar and or cubase.
just select the asio driver from the audio settings inside reason, connect the asio module to a mixer inside the pulsar project to run only reason standalone without any other sequencer.
in order to use it with cubase you need to first start cubase and after its started you can just start reason, it will automaticly enable rewire and everything will be synced. you will be able to use reason as a soundmodule too, by playing reason synths from inside cubase.
check the manuals.
cheers,
sander
check the manuals.
cheers,
sander
I have Reaon, as Rewire Instrument in cubase and as ASIO guest, running smooth, real smooth
under XP. I go to about 80% on my dual PIII 1GHz beofre I get clicks. Lots of channels, lots of fx. Everywhere. And yet no finished songs
Try updating your Cubase again after Reason install, if you have no Rewire ports you can enable in Cubase.
How do you mean update Cubase after Reason install? (installing Cubase after Reason or is there some update?)On 2002-03-20 13:47, at0mic wrote:
I have Reaon, as Rewire Instrument in cubase and as ASIO guest, running smooth, real smoothunder XP. I go to about 80% on my dual PIII 1GHz beofre I get clicks. Lots of channels, lots of fx. Everywhere. And yet no finished songs
I have to restart my PC before he's start working normal
THANK YOU
Let me explain how I did install here:
-Cubase 5.0 from CD
-Reason
-Rebirth
-Cubase 5r2
I suspect when Cubase's installed, it's not really ready for Rewire sometimes. When my Rewire guests (Ra & Rb) are installed, I've given Cubase 5r2 a reason to install the Rewire facility, cos Ra & Rb are already installed now.
In theory, you should just install whatever you like first. But that's how I mostly do it. If you're experiencing problems w 'no Rewire channels to activate in Cubase' then do the 5r2 setup again, or the other highest update.
It's just PFM and voodoo, but that's how I do it. And that might be a solution for you.
at0mic.
-Cubase 5.0 from CD
-Reason
-Rebirth
-Cubase 5r2
at0mic.
Don't expect miracles to happen
2 Rewire problems, 2 solutions:
1° Cubase has no, zero, Rewire channels to activate. Then update Cubase.
2° Cubase says 'not enough audiochannels': then reduce the amount of Reason reserved channels to 16 (by applying the patch in Reason folder) or decrease the number of audio channels.
Ie. your Cubase has a max. number of channels, depending on the version. Imagine you can load 64 channels. If you're using 32 Rewire-, 16 VSTi and 16 audio channels, you're on the limit. You will now have to remove one kind of channel to make a new one of the other type.
