why less 3rd parties are making plugs for creamware?
you already asked a similar question here: http://www.planetz.com/forums/viewtopic ... 16&forum=1
and if your pulsar2 is so bad, please sell it to me
this way you can use your energy and money on "better" products
Because the userbase is to small.
And because it's a closed system.
If you write VST/DirectX/R-TAS plugs, you only need a C++ compiler and a Software SDK. With Pulsar/Scope on the other hand, you need the Scope/DP hardware/software and a Sharc Developer kit from Analog Devices.
Also you need to learn the Scope/DP software, wich is very different from coding.
Kim.
Kim.
you think i don't want pulsar to be better??On 2002-03-17 11:15, musquash wrote:
and if your pulsar2 is so bad, please sell it to methis way you can use your energy and money on "better" products
more 3 parties will make creamware bigger and better support, and even better DSP plug qualities.
I'm still seeing new things in life.
<p><a href="http://mp3.com/dxl">www.mp3.com/dxl</a></p>
hope timework still with creamware
just found other 2 they are still having some action
http://www.huicholity.com/newshop.html
http://www.dspdev.com/products_verbgold.asp
but super dsp hunger plugs.....
whatever you think!
King of Snake
I thought the Phatsync from FXpansion (in the NAMM brochure) was new? I know it from Cubase but didn't know it's for Pulsar as well. If it's new than it seems FXpansion didn't quite making pulsar stuff just yet, if not, forget I ever said this.
<font size=-1>[ This Message was edited by: King of Snake on 2002-03-18 11:53 ]</font>
