No, it's not so exclusive, but it's a way to attract your attention:
to INGO, or other PRO user, this is a simply request : why somebody with a good knowledge about tweaking can't do a service to all Pulsar user ? I mean: divide all MOBO (I think that the bigger problem here are the different mobo Chipset) and say for everyone how to obtain good performance, using Tweakbios, or Wpcredit, or anything else. I simply asking a page with detailed istruction, and not 100 different hint without a sure solution. I think that everyone of us want to work well, with a stable system, and it's impossible that nobody could say one single good solution. The message is especially for Ingo, or for Creamware tech; I have my new PC three month ago, and with all the solution I can't solve my problem (PCI master overflow), installing patch, new bios, new driver, tweaking left, tweaking right..........it's IMPOSSIBLE ??? Why nobody could explain to me how to solve this problem ?? Before this system i've got P3 450 with VIA Apollo pro, and PCI error appear sometimes; now with 'the good....' AMD761 PCI error appear while loading Cubase !!! I can work only with DMA disabled !!
Sorry for bad English
Thanks in advance
P.S. The last hint I try is to higher CAS timing of the RAM becuse the real problem it's not the Motherboard but the RAM !! Every week the problem change......this make me crazy, becouse no solution work for me.
++++EXCLUSIVE+++++
AAAAAAh.....I'm sorry !!!!! I don't want to be a bug for this forum !! Sorry Subhuman, I don't want to offend nobody. My nervous is not right. I will try to post a regular question, to obtain a regular answer.
I'm not so newbie on this forum ( I use Pulsar from 1999 and i post sometimes 'DP or DanPow') but I always work good with this card....until I change my PC. Now I got many problem and I can't solve it. Later i post my configuration and I hope that someone could help me.
P.S. : I know the knowledge of Subhuman, and with my provocation I wanted to scroll his big brain to help me........
some post ago I've posted my configuration with pics of my system, but nothing happen....
I will try again..
sorry for bad english
Bye
I will try again..
Bye
I'm not offended guys, no worries.
I would be a LOT more likely to give you advice if you posted this to ONE forum here in PlanetZ and didn't demand we give everything away for free. And gave a bit more information including details like IRQ, software versions, window verions, driver versions, etc, because that just makes it much easier.
Pick of one your 5 versions of this thread, and respond to it. None of us want to go hunting around to find where the answer would be.
He is just disspointed, and nerverse, don't want to waste that money, wana get to use his pulasr properly.
I'm still seeing new things in life.
<p><a href="http://mp3.com/dxl">www.mp3.com/dxl</a></p>
<font size=-1>[ This Message was edited by: dxl on 2002-03-13 17:30 ]</font>
