What audio program sounds better? (Logic Audio or Cubase)???
Drum-Maker
Post by Drum-Maker »
Hi all,
I'm a Cubase user, and I don't know why there are people saying that Logic Audio sounds better than Cubase??
Is there a difference between the Asio2 In and out or what? Is there anybody that could make clear this fact ?
Because if is there a reason to change in Logic audio (because of a better sound) .... then .... i will change immediatly!!
Then the question is: Is there a "sounding" difference between Logic and Cubase
Thanks in advance for the idea or answer (all is well accepted)
Excuse me for my bad english...
Regards
<font size=-1>[ This Message was edited by: Drum-Maker on 2002-03-12 17:49 ]</font>
borg
Post by borg »
search your answers here: http://www.planetz.com/forums/viewtopic ... forum=5&45
there's a nice search function :wink:
andy
the lunatics are in the hall
kiminet
Post by kiminet »
They are both very high quality soundwise.
The discussion is a religous matter.
Kim
RedSun
Post by RedSun »
Yep, you're right.
Both have excellent audio engines. It's mostly a mather of which one is most pleasing to your hear.
RedSun .:.
sandrob
Post by sandrob »
i found that wavelab sounds better than soundforge and cakewalk better then logic even cubase. but muzis sound much better then any other audio program. only winamp sounds better :lol: :lol: :lol:
btw: this is joke! :roll:
oooops! i forget to test nuendo and microsoft word :sad:
<font size=-2>"without deviating from the norm, progress is not possible" - frank zappa</font>
<font size=-1>[ This Message was edited by: sandrob on 2002-03-13 03:09 ]</font>
yep, the best one is the one you got and like.
(i got and like logic :wink: )
Drum-Maker
Thanks for the replyes,
I continue to work with Cubase, because I know better how does it work! I tried to install a demo version of Logic, but I can understand nothing in logic!!
I had crashes all the time... but I don't know what's the matter.
If I've understand right the sound is equal in both audio engine, the only matter is the "know-how" of the program.
Anyway, I would thank all folks here in PlanetZ.
:smile: Regards :smile:
King of Snake
Post by King of Snake »
As far as I've been able to tell from the numrous discussion on this topic, Logic and Cubase (from version 5 upwards, 3.7 had problems) basically sound the same. Of course the built-in eq's, effects and other dynamics will sound different so that's a matter of taste.
The new Cubase SX, coming in June (I hope) will feature a new audio engine based on Nuendo, so it'll probably be better still. :smile:
kimgr
Post by kimgr »
The audioengine in Cubase5, CubaseSX and Nuendo are EXACTLY the same.
At least that's what the Steinberg developers told me yesterday in Frankfurt :smile:
Kim.
kensuguro
Post by kensuguro »
And it would be quite wierd if that minute difference between steinberg line of softs and logic could kill or make live your mix. So I think, work with anything you've got! Shew, big difference! If you know Cubase, then work with it unless you've got enough motivation to go through the process of learning a new software. Even if Logic was better than Cubase, you'd still have a couple of month of leraning time. In the end, it's a no win deal, the change causes your creativity to slow down. (atleast during the switching period) But sometimes a big change to refresh your mind is good. :smile: Just like an occasional synth even if you're not dieing for it. Now that's what I'd like just right now! hehe.
King of Snake
Hmm, well than maybe it's just the audio editing/automation feautures that are based on Nuendo if the engine was already the same.
kimgr
Post by kimgr »
You are correct.
