BC Shell pgr change
Sextant
BC Shell pgr change
Post by Sextant »
Hi everybody
Does BC modular shell reacts to program changes to change preset? I try but don't succeed with PC sent from Live. I ask because midi channel choice from devices window doesn't work. Only midi in module inside the shell seems allowing choosing midi channel (so more large question if there's a midi pb with BC shells)
Sextant
Re: BC Shell pgr change
Post by Sextant »
Sextant wrote: Sat Mar 22, 2025 7:49 am Hi everybody
Does BC modular shell reacts to program changes to change preset? I try but don't succeed with PG sent from Live. I ask because midi channel choice from devices window doesn't work. Only midi in module inside the shell seems allowing choosing midi channel (so more large question if there's a midi pb with BC shells)
Presets are what can be assigned to program change messages. Some, like Jimmy, used control over the entire project at once so a single program change propagated to everything. That's workflow.
sunmachine
Post by sunmachine »
Spielraum posted a video tutorial here: viewtopic.php?p=369384#p369384
The key is to enumerate the banks and presets properly.
Sextant
Post by Sextant »
sunmachine wrote: Mon Mar 24, 2025 3:52 am Spielraum posted a video tutorial here: viewtopic.php?p=369384#p369384
Thanks!
The problem is that nothing happens in this way with me: the vstclock plugin is not recognised by live and I configure my pgm ch in the same way but it doesn't work.
sunmachine
Does sending the bank change/program change work with a different application (like MIDI-OX for example)?
Did you copy the ScopeVSTClock_VSTPlug.dll into your plugin folder that is used by Live?
"ScopeVSTClock_VSTPlug.dll" is an XTC component I presume? Are you using XTC mode?
Also, program change for modular shells will only change between knob settings, how exactly are you trying to use it?
