Visual debugging/Readout for modular3
the19thbear
Post by the19thbear »
I'm trying to do some logic in mod3 and would like to be able to debug stuff.
In order to see if logic is working as it should, i need visual feedback/readouts.
I can't seem to find anything anywhere.
Is this something that exists for mod3?
Right now i'm trying to read what comes out of BCMs Async event counter. But I don't know a way to display this info.
Re: Visual debugging/Readout for modular3
Flexor's Constant Val monitor and similar tools from BC Modular. I don't have Scope open at the moment to recall each tool name, but they are there.
the19thbear
Thanks. I dont have flexor since they cost money.
I can’t seem to find anything built in, in mod3.
Feel free to let me know once you open scope.
Thanks Valis!
https://www.styledriver.eu/scope/modula ... NTROL.html
Look at the Constant Val/Freq/Time etc modules.
Flexor has some advantages in that every module calculates on every sample (implemented with low level math adders by Assaf rather than the SDK tools that come in the Scope SDK) but those should work fine.
the19thbear
Thanks Valis.
I looked over the page but can't find anything that can display a value based on an input.
Maybe i'm just blind but it doesn't really seem like anything useful is there.
Might have found something useful in the CWM "Valmeter". Will check it out later.
Thanks for your time :)
Constant Val & Constant Val Bipolar? And several others for their specific input types?
the19thbear
I have tried them. They only have outputs. They are for generating values. Not reading them.
Rafe
Post by Rafe »
the19thbear wrote: Thu Mar 06, 2025 9:11 am I have tried them. They only have outputs. They are for generating values. Not reading them.
Gotcha, sorry. Since I have Flexor I always use VAL monitor, and I assumed the value display on that worked the same way.
the19thbear
valis wrote: Thu Mar 06, 2025 7:48 pm
No problem. Thanks for your time no matter what :)
the19thbear
Rafe wrote: Thu Mar 06, 2025 11:22 am Val monitor CWM
That was the one, thanks
the19thbear wrote: Thu Mar 06, 2025 10:34 pm No problem. Thanks for your time no matter what :)
I haven't played as much with Mod in a while, you've actually got me thinking about installing BC Modular on my Xite system and learning the quirks for modular there, most of my modular time was spent on my legacy PCI era system.
the19thbear
DO IT!:)
