Activating
frango
Activating
Post by frango »
Hello community,
I had this weird life situation. All in all, I purchased pulsar 2 on 2000. and sold it 2006. then in locally make a circle in my country and came back to me again last year :)
The thing is I installed it using PCI to PCIe adapter on my new comp but cannot activate it. I installed 7.0 Sonic core software with all requirements, turning off win10 check and all (maybe I didnt need this). Anyway how to import keyfile which is shown in app folder but it doesnt work? Second question is what is difference between SDK 7 and Sonic 7? Do I need both installed or not. I did install SDK and key from it works when I start Sonic 7 and vice versa, When start Sonic 7, key from SDK works but at the end says something is not installed correctly and doesnt let me in app.
thanks
frango
LunaMan
Re: Activating
Post by LunaMan »
You only need SDK for development of new devices. If you only use Scope for music production you don’t need sdk.
frango
Re: Activating
Post by frango »
Thanks...anyway I sent my problem of acrivating to scope product and waiting for their answer.
nebelfuerst
Re: Activating
Post by nebelfuerst »
You should check in device manager, that your pulsar2 is visible there. Check the driver date, it should show 2017.
As far as I remember, I just entered the single key for scope7 and it worked.
SDL might need both keys, so you should get scope7 running first.
frango
Re: Activating
Post by frango »
Ok I realised I cannot install 7 ver.cause need to buy it, stupid me but 5.1.havent keyfile too. Am I on the good way when send request string to support? Is 5.1.free or not. I removed manually 7 drivers so I installed 5.1, its from 2010 as shown in device manager.
Re: Activating
actually v5.1 is twice as expensive as v7. SC no longer sells v5.1.
frango
Re: Activating
Post by frango »
Thanks for reply, I will go with 7 for sure then.
