Which CPU is the fastest that Scope boards can use. I want an updated unit that can deal with a lot of plugins and processing but would like the Scope converters for mixing.
Fastest processor Mobo for Scope
Music Manic
nebelfuerst
Re: Fastest processor Mobo for Scope
I guess you mean Scope boards as PCI cards, not the pcie cards of Xite.
In this thread are some boards within the posts.
viewtopic.php?p=366564#p366564
The "fastest" CPU is hard to determine, as for some applications a large multicore cpu will be slower than a lowcore cpu, the same with intel vs. amd. Nevertheless I never reached a cpu limit with my vintage I7 in Bitwig. Do you use so many VSTs or just a few very cpu intensive ones ?
Music Manic
Yes PCI. I would like intensive VSTs plus multiple EQs etcnebelfuerst wrote: Wed Nov 13, 2024 9:09 am I guess you mean Scope boards as PCI cards, not the pcie cards of Xite.
fidox
Depends. Since I have 3 pci cards, I'm limited to 7th generation Intel i7 7700K and mobo which has 3 pci slots.
I think, the last generation mobos for commercial use, with 3xpci slots, unless if you search for industrial mobos, which is too expensive option for me atm.
Anyway i'm doing a lot of processing from plugins to export audio, especially CPU hungry ones,
so at the final mix I have just few vst's loaded and lots of audio tracks.
- garyb
- Moderator
fidox wrote: Sat Nov 16, 2024 5:12 am Depends. Since I have 3 pci cards, I'm limited to 7th generation Intel i7 7700K and mobo which has 3 pci slots.
which is the only sane way to work anyway.
