Want to Trade Cable Whip or Plate.
t_tangent
Post by t_tangent »
I would like to trade or swap, or buy, either a Plus cable whip or a Classic Plate for a Pulsar II card. Preferably I'd like to get a Classic plate but would consider the alternatives.
Quite a few years ago I bought a second hand Pulsar II card from a member of this forum as a spare but which I also use in my workbench PC. At the time I purchased it the seller told me it was a Pulsar II with Classic type cable whip. So when it arrived I installed it in my workbench PC and since then I have just used the RCA Phono type analog outputs on the cable whip and for years it has just been feeding some small powered speakers and works fine in that respect.
However I now have a need to use the digital input & output but I'm having connection & sync issues over the SPDIF I/O. Investigating further, I have only now discovered this so-called Classic plate on the Pulsar II card is in fact a Plus plate. This means all those years ago the seller sent me the wrong combination of Plus plate and Classic cable whip, although I am sure he didn't realise this either.
So I either need to swap this Classic cable whip with someone who has a spare Plus cable whip, or swap this Plus plate with someone who has a spare Classic or Z-Link plate.
Or I need to buy a Plus cable whip, or a Classic or Z-Link plate.
I’ve attached some photos showing my plate and cable whip.
So if anyone wants to do a swap or can help me with this please let me know or send me a PM.
I am located in UK.
Many thanks.
Tim
Plus Plate that came with the Pulsar II.jpg (3.04 MiB) Viewed 19446 times
Classic Cable Whip that came with the Pulsar II.jpg (1.53 MiB) Viewed 19446 times
Re: Want to Trade Cable Whip or Plate.
https://www.scopeusers.com/ScopeRise/is ... ub_mst.htm
pinouts, in case you want to make a break-out cable....
Let me check my spare cards, I may be able to swap you plates.
t_tangent
Post by t_tangent »
Thanks very much.
Yes I was thinking of making my own Plus cable if I had to. But swapping the plate would be better for me so thanks for checking when you have time and I’ll wait to hear from you. :)
Xite Knight v2.0
Location: The Kingdom of Denmark, including The Faroe Islands and Greenland
Post by Xite Knight v2.0 »
