Hi, i've got a problem recording with Pulsar; using Cubase, when i try to record more Tracks (with effect) on one track, the audio sometimes stop, and this heppens every time i do this; I don't want to use The mixdownd, becouse i want to use Pulsar BigMixer; i've try to use Wavelab to record with WAve device, but it's instable (i've PIII 450 256Mb hd UltraATA66) In the Asio PAnel i use the bigger value for all parameters, but is not enough.
There is a way to solve the problem, or i've got to buy a good SCSI disk ?
Sorry for bad english...
Thanks in advance
Bye
DanPow
Audio instable... (by DanPow)
Guest
Subject: you won´t need to buy an expensive scsi disk...
i don´t know cubase very well, so i just can say that it might NOT be your hard disk. the performance of modern IDE disks is definetively high enough for these purposes; don´t spent the money for a SCSI disk. your problem lays somewhere deeper in your configuration. perhaps the hard disk runs in an old PIO-mode, or your system works in DOS-compatibility (....is that translated correctly? my english also isn´t so well...)
try to odd out possible errors, to get nearer to the problem.
gruß,
Mo
gruß,
Mo
Guest
