is dNa gone ?
dNa Devices discussion & support
Moderators: valis, RA
is dNa gone ?
http://dnamusic.nl/dNa.Scope/
website doesn´t load here and links in Sonic Core shop don´t work either.
sunmachine
Re: is dNa gone ?
Post by sunmachine »
That link is working here (only with http, not with https, though).
Re: is dNa gone ?
unfortunately not here,- http://dnamusic.nl/dNa.Scope/
Opera browser ...
ERR_CONNECTION_TIMED_OUT
same in Firefox ...
when I try just only http://dnamusic.nl it´s the same too
:roll:
sunmachine
Re: is dNa gone ?
Maybe a DNS issue. What do you get when you execute nslookup dnamusic.nl on the command line (cmd.exe)?
It should return the IP address 91.217.57.78 if all works fine.
You can also test if you can reach the server by using that IP address in your browser: http://91.217.57.78/dNa.Scope/
It should return a Not Found error from the Apache server (since it needs the domain name to properly fulfill the request).
If you get a proper answer from the DNS server and can reach the dNa server via IP address, then you could also check if there is an entry for dnamusic.nl in the hosts file, which should be located in C:\Windows\System32\Drivers\etc if it exists. View (and edit) it with a plain text editor like Notepad.
nebelfuerst
Re: is dNa gone ?
Post by nebelfuerst »
Website works for me. You can use DNS-server like 1.1.1.1 or 8.8.8.8 to override your provider's dns.
LunaMan
Re: is dNa gone ?
Post by LunaMan »
Link works here on my phones Safari browser.
Re: is dNa gone ?
sunmachine wrote: Tue Aug 27, 2024 8:43 am Maybe a DNS issue. What do you get when you execute nslookup dnamusic.nl on the command line (cmd.exe)?
Well,- I´m on Win10 22H Pro x64, latest build and it´s the only site showing this issue here.
I´m absolutely not good w/ these server things and when I insert " http://91.217.57.78/dNa.Scope/ " into Firefox and press ENTER, I get a black page.
When I do the command line thing,- I get nothing except an extremely fast closing windoq once I clicked "o.k." or pressed ENTER.
sunmachine
Re: is dNa gone ?
Hmm, the command line window should actually stay on screen. I don't have a Windows machine to try it on at the moment, but the following steps should work:
1. Press the keys [Windows] + [R], enter "cmd" and press [Enter] to open the command line window.
2. Enter "nslookup dnamusic.nl" and press [Enter] in the command line window. It should display the result and the window should stay open. What's the output?
You could also run the following commands in the command line window:
curl -I http://dnamusic.nl/dNa.Scope/
or
curl -I http://91.217.57.78/dNa.Scope/
and post the output here.
Re: is dNa gone ?
thx sunmachine,- I get a entire black command line window w/ blinking curser as the result.
I´m now typing on my Win10 Pro x64 laptop and it´s the same behaviour I recognized on my office desktop machine,- Firefox and Opera.
I´m pretty sure it´s the "http" vs "https" problem,- some security stuff.
Seems, current browsers won´t open "http" websites anymore.
Using dNa link from google or duckduckgo doesn´t work either.
sunmachine
Re: is dNa gone ?
So did you get the IP address when executing nslookup dnamusic.nl?
Does http://www.cwmodular.org/ work, which is also http only?
Re: is dNa gone ?
sunmachine wrote: Wed Aug 28, 2024 10:40 pm So did you get the IP address when executing nslookup dnamusic.nl?
NO, unfortunately I get a rapidly disappearing black command line window where I´m unable to read the text.
There´s some,- but once I typed "nslookup ..." and pressed ENTER, it comes up and is gone again in a fraction of a second.
sunmachine wrote: Wed Aug 28, 2024 10:40 pm Does http://www.cwmodular.org/ work, which is also http only?
Yes,- it launches lightning fast !
Everything works here, except the dNa link. :-?
A.t.m. I´m trying to get the dNa-link working on my Win11 Pro x64 laptop and it doesn´t work also.
In addition to the timeout error, there´s a german message "nicht sicher" (means: precarious/unsafe connection/site).
Now it happens in Firefox, Opera and Avast Secure Browser too.
I´d say, dNa urgently needs a "https://" header website.
sunmachine
Re: is dNa gone ?
Is the HTTPS-Only mode in Firefox enabled? Maybe you can turn it off (for dnamusic.nl)?
See here: https://support.mozilla.org/en-US/kb/https-only-prefs
Re: is dNa gone ?
sunmachine wrote: Thu Aug 29, 2024 12:01 pm Is the HTTPS-Only mode in Firefox enabled? Maybe you can turn it off (for dnamusic.nl)?
Thx for reply !
No,- HTTPS-Only mode isn´t enabled !
And, it also doesn´t work in all the other browsers I use and that rules for 3 computers now, Win10 and Win 11.
Strange behaviour IMO.
sunmachine
Re: is dNa gone ?
Strange indeed.
RA
Re: is dNa gone ?
Post by RA »
Hi guys...sorry i was busy with life...i can open the website...is there a problem?
You guys can always contact me directly...also from here. Let me know if something isn't working with the site
Cheers ray
Re: is dNa gone ?
RA wrote: Sun Oct 27, 2024 3:22 am Hi guys...sorry i was busy with life...i can open the website...is there a problem?
Cheers ray
FIrefox (example) and Opera,- which I both use on all of my machines,- and Avast Secure browser (only on 1 of my laptops),-
I can load all of my countless bookmarked websites,- but not your´s unfortunately,- regardless where I use the/your link.
For the example pic, I used the link you provide in your post´s signature and it´s the same when I use the link from S|C shop.
1.) normal behaviour w/ https:// websites (... and https only is NOT enabled !)
2.) that´s how it looks when I load your site and it´s not a temporary issue, instead it´s always the same since a long time.
On my side, there´s no way to change.
IMO, you need the https:// thingy.
RA
Re: is dNa gone ?
Post by RA »
Thanks Bud...i will look into this. But im not as fast as i used to be 🫣
Re: is dNa gone ?
RA wrote: Sun Oct 27, 2024 9:18 am Thanks Bud...i will look into this. But im not as fast as i used to be 🫣
No problem, take your time.
I was just only looking for news when I recognized the link issue.
But can be I need something in a few weeks.
