Update scope 7
Update scope 7
Good morning to everyone, wanted to know if there is an update to scope7. Thank you. Claudio
						Re: Update scope 7
Can you be more specific on *why* you are looking for an update?Ciairo wrote: Thu Aug 22, 2024 12:06 am Good morning to everyone, wanted to know if there is an update to scope7. Thank you. Claudio
I.e.
1) an update compated to what? What version do you look for an update to?
2) Why do you need an update? Are you looking for a fix to a specific problem?
I think this wouold make it easier to find an answer for you...
Re: Update scope 7
The reason is that I can't synchronize scope 7 in slave with the samplerate bnc. I use Windows 10 with Xite-1. They should release, with the update to scope 8, a configuration file that solves this problem.
						Re: Update scope 7
On scope 5.1 the bnc synchronized without problems with slave.  But with version 7 you can't make it work. I have several devices synchronized with the BNC, including the Xite. Can anyone help me? Thank you!!
						Re: Update scope 7
I have it clocking as slave here, the answer is on the forums but I forget where offhand. I slave mine to a Line6 Pod HD Rack when I use that for recording.
						- Bud Weiser
Re: Update scope 7
viewtopic.php?p=343694#p343694
viewtopic.php?p=354561#p354561
IIRC, these were the most important threads ...
