2. Is there somekind of separate routing (background) program running in the XTC-mode? My TC M-One is in sync in the Elektra SP-DIF loop but when I route signal to the SP-DIF in Nuendo nothing goes to the M-One.
3. I get a lot of snap, crackle and pop. I'm using 24 bit 44.1 KHz with 25 ms. I tried 13 ms and got a lot more similar pops. The 25 ms is the maximum value, is there any other way to remove the clicks? Does the ULLI settings affect the XTC-plugins? For example does a compressor work with less latency with lower ULLI settings or does the ULLI affect only the I/Os?
My setup is Nuendo 1.5.3, Pulsar2&Elektra, P667, 512 MB RAM, Abit BE6-II, IBM 75GXP, network card, Matrox G400. The project is running 24 24 bit 44 KHz tracks with 2 MasterVerbs, few compressors and Nuendo eqs.
Thanks in advance, these things cannot be found in the manual..
