hi , i have a small problem.
every time i'm loading project into pulsar , cubase gives me "asio error" messege , it's clear that the sync between cubase and pulsar breaks , but is there solution to this problem ?
gelder
cubase asio problem
Guest
Subject: Cubase asio problem
Everytime you close (and then load) a project, if Cusase is open, you discharge your asio device and Cubase say you "asio error"; is normal.
Is better to lunch Pulsar before Cubase, if not you must reset in Cubase your audio setting/asio scope device.
I don't know if there is a solution but you can try to save a project, with asio device (in/out) connected to Pulsar, as windows default proj.
Maybe that when you change your project, between the first and the second proj., the system keep reference to the default win proj.
I'm not sure but you can try.
Warning! If you has't update Pulsar to release 2.04, your sw has a Bug that not permit to change the desktop mode ("OS" "Pulsar") if you save a project as Pulsar default.
Read my post in "Pulsar Problem".
By and Merry Christmas.
Guest
Guest
