Problem with Pusar and Cubase
sandrob
Post by sandrob »
After 4-5 years, I finally changed all the capacitors on the Pulsar 2 card and installed it in the computer. Media Player works normally, but with Cubase I have an ERROR - ASIO drivers cannot be loaded.
Does anyone know what the problem is?
pulsar 2.JPG (58.76 KiB) Viewed 23557 times
nebelfuerst
Re: Problem with Pusar and Cubase
Post by nebelfuerst »
Which versions of scope, windows or cubase do you use ?
Spielraum
Post by Spielraum »
sandrob wrote: Thu Jun 06, 2024 11:47 am Does anyone know what the problem is?
from win10, you need scope7
for Cubase, i would use either an ASIO2 source or an ASIO2 flt source and an ASIO2 dest.
sandrob
Post by sandrob »
nebelfuerst wrote: Fri Jun 07, 2024 9:04 am Which versions of scope, windows or cubase do you use ?
Scope v5.2709, Windows 10 and Cubase 13
sandrob
Post by sandrob »
Spielraum wrote: Sat Jun 08, 2024 4:56 am
Are you sure?
Version 5 worked fine for me with windows 10 before I changed the capacitors. Probably there was some error that I don't know how to solve.
sandrob
Post by sandrob »
garyb wrote: Sat Jun 08, 2024 8:42 am for Cubase, i would use either an ASIO2 source or an ASIO2 flt source and an ASIO2 dest.
I tried both combinations. Here I have attached a picture of the project that worked normally for me before the capacitors on the card were changed.
It seems that there was a hardware error... The only thing I don't understand is why multimedia drivers work and ASIO doesn't.
fidox
Post by fidox »
Scope platform works just nice with, I have :
Windows 10 64bit - Scope 7 - Cubase 13 Artist
Windows 11 64bit (also worked with Windows 10) - Scope 5 - Cubase Elements 12
Just remembered, since I had some problems running Cubase Elements 12-Scope 5 (ASIO was not recognized) ,try this :
sandrob
Post by sandrob »
fidox wrote: Sat Jul 13, 2024 10:46 am Scope platform works just nice with, I have :
Thanks! I'll try. :)
fidox
Post by fidox »
This was my original post, then at the end of post I figured out the solution for me :)
viewtopic.php?t=37359
sandrob
Post by sandrob »
fidox wrote: Sat Jul 13, 2024 11:11 am This was my original post, then at the end of post I figured out the solution for me :)
I'm using RME now and I'm at the stage where it's difficult for me to install and try Pulsar, but when I'm able I'll let you know the result.
Scope via ADAT into RME has been my usage since 2003
sandrob
Post by sandrob »
valis wrote: Sun Jul 14, 2024 6:05 pm Scope via ADAT into RME has been my usage since 2003
Smart combination!
Unfortunately, my slots are full and there are no more places.
I use two machines!
The Scope PC can be whatever it needs to be. Both my PCI based system and my Xite (PCIe) are running 2015/16 era workstation boards with 4 core Xeon chips, and have zero issues aside from the few documented concerns with Scope 7 on 64bit.
The downside is heat, but I have way more machines in here than just those two anyway, and the Scope boxes run so cool and stable I barely notice they're there.
sandrob
Post by sandrob »
valis wrote: Mon Jul 15, 2024 3:56 am I use two machines!
Aha! I understand :)
Thanks for info :)
