Hello ,
i' don't inderstand why my plusar V.3 don't work in midi mode on W.2000 and cubase 5R06
I'have a pulsar1+powersampler
cubase said midi output -> luna/ps/elektra
in window pulsar i' have sequencer source connected to one pulsar synth and pulsar synth out to asio dest for monitoring in VST input
WHEN Y PLAY ON MY KEYBoard ... Pulsar synth no receiving midi signal,
I think the config cubase is good ,because my midi output to hardware synth is good (yamaha cbx driver)I have signal midi and sound in asio vst
it's strange because output midi are luna/PS/elektra in cubase and not pulsar midi out ???
and i have in control panel/multimedia/ pulsar/proprietes... the scope midi so in MCI
/peripherique sequencer midi/ midi out scope
THIS iS not THE RIGHT DRIVER that cubase report ???
5U4U help
pulsar midi on WK2000
hi seb,
i'm a mac user, so maybe not of much help, but in my system, there's not a single driver named as it should be (as indicated in manual). everything is called 'creamware' or 'scope' something, but they all work fine for me and my pulsarII board. i'm not a tech head at all (how i sometimes wish to be one
) but coming to this site helped me a lot!!!
hopefully for you some of the big boys over here will help you on your way. wait until the other side of the atlantic wakes up
andy
the lunatics are in the hall
jetseb2002
... Hello i'ts me , and my prob is resolved
When yo have a pulsar and a dsp board (powersampler for me) in K2000
you must install in first pulsar (irq9 for me) and powersampler
(irq10 for me) after the reboot
Now cubase said pulsar midi 1 and 2 in output and no Luna/ps/elektra
in output midi instrument 1 et 2
so midi signal arrive in the sequencer midi source 1 in project and
continues to the synth connected (light move ...when i play in
keyboard) it's very very good
yes pulsar midi is ok on k2000 with 2 PIII in smp mode (i' don't know
todays the limit but it fell good)
i 've inverted the card on the pci , i 'don't known if creamware
known that the luna/ps/elcktra is not routed on sequencer midi source
on os pulsar (in control panel it's a scope driver midi device that
is showed )
thanks for you help
with direct acces midi (din) to my cx2 with no sequencer in the party
and i've listen the sound ... after i think it's the module sequencer
or the to host connection synth (but no) or the version of cubase
(but no:) or the story of the drivers in 2000 ....
is showed )
thanks for you help
To make easy for myself:
http://www.planetz.com/forums/viewtopic ... &forum=3&2 might be interesting for you.
