Hi all,
I am owner of Luna II board for about half a year and everything is fine.
Recently I've installed yahoo-messenger but was unable to get audio in messenger to work correctly. I can hear my frends, but my voice is somehow slowed down and deep (it seems like something is wrong with sampling rate). I've tweaked the properties of my Luna card and followed the "audio setup wizard" from Messenger but without success.
I have all necessary codecs, also.
Thanks alot for your help in advance.
Luna II - Problem with Yahoo- messenger
Eeek, AIM on a DAW
I just hope you turn it off when you're recording. First, I am assuming you're using Luna2 V3.01 software?
To get it to work with the V3.01 software, reinstall it and don't edit the background project. Run AIM (eeeeek!) with only the background project then, it should work. Make sure in your Driver Settings in Device Manager (assuming you use a PC here), make sure "Enable all sample rates" is checked.
Hi Subhuman, thanks for your fast reply.
I'm using Luna2 V2,5 software, and "AIM" is on Internet partition of my dual boot Windows 98SE.The "Enable all sample rates" is checked and I will try to reinstall everything as you said.
PS: Sorry, but I'm not sure what "AIM" is standing for (I assume it's about Y.Messenger).
