Mix AB+ | 2to2S | 1send | 2to2 G
spacef
Post by spacef »
The devices in the attached zip are used to manage signals when using external mono effects such as spring reverbs or guitar pedals.
>>> Spring reverb tank on Scope/Xite https://www.forums.scopeusers.com/viewtopic.php?t=37305
Both devices are MIDI and preset able.
You can change the name of the project module by typing under the device name at the top-left of the panel.
Also found here: https://spacef-devices.com/free-downloads/
2to2S
- Used as a "return utility" from 2 external mono effects. it includes 24dB gain, phase invert and insert Fx (1 mono, 1 stsreo).
- The "Blend" controls allow to crossfade between "Fx 1 post-pan" or "post Fx2": for example, if you have an Eq and a Phaser, you will crossfade between "Eq+Pan" or "Eq+Pan+Phaser"
Outputs:
- LR output is the mix, to send to a scope mixer for monitoring
- 1L / 1R outputs channel 1, to send to asio for recording
- 2L / 2R outputs channel 2, to send to asio for recording
Mix AB+
Used to send signals to 2 external mono effects.
3 inputs per channel allow to plug sources once for all (for example, an asio source, a wave source, an aux send from a mixer).
You can use mono insert FXs and crossfade between "post Fx1" and "Post Fx 2" : if you have an Eq and a delay, you will crossfade between "Eq only" and "Eq+Delay".
You can name all sources (A1, A2 etc).
ADDED TO THE PACK
- 1 Send (single channel of MixAB+)
- 2to2G (like 2to2S with special Gate)
Enjoy !
Send and Return Utilities.zip
(1.74 MiB) Downloaded 334 times
plug-ins for scope
SpaceF website
SC website
Re: Mix AB+ and 2to2S
Wow,- these look great !
Many thx for upload !!!
spacef
Re: Mix AB+ | 2to2S | 1send
Post by spacef »
Added "1-send.dev", a single-channel version of MxAB+ , with the same functions.
Download in the first post (1send.zip)
Tip: the crossfader can be used to add a dry/wet function to the second insert effect. Useful for effects that do not have dry/wet, such as filters, autowah...
plug-ins for scope
SpaceF website
SC website
spacef
Re: Mix AB+ | 2to2S | 1send | 2to2 G
Post by spacef »
Hi all!
Proudly adding "2to2G" to the pack.
It is like 2to2S but with a home made Gate/Noise Gate.
I first wanted to add a noise Gate, but ended up doing a gate from scratch (only way it would work as wantd).
Then tuned it to sculpt reverb tails, also tested on speech, drums beats...
The GateGlue parameter "glues the gate at the top" i.e. fully open, and closes with a delay, allowing to get rid of short modulations and thus avoiding unwanted "pumping effect". it is a bit like a "Hold" function, but which is relative to the input sound.
More info in the pdf in the zip.
Also all devices were revised (graphics alignment, preset list names...).
Please note: I had to remove the old and reload the updated devices in the Xite project, otherwise some changes were not taken into consideration:
In Mix A/B and 1-Send
---- the 3 mix input levels mid position should be -19.7 dB instead of -24dB
---- Send middle position is now -12dB instead of -24dB (easier to use with mouse, not yet tested with midi CCs).
You can find it in the first post or on
plug-ins for scope
SpaceF website
SC website
spacef
Post by spacef »
2to2-G vu meters of the Record Channels were not reflecting actual output (vus were panned even in Mono mode).
Now corrected (connected to the record channel actual outputs).
Updated as a seperate device (2to2-C ) https://spacef-devices.com/free-downloads/
or in the Mono Sends and Return Pack (was updated with that 2to2-C version)
or in the above attachment (1st post)
Sorry for the multiple downloads and delay in correction, as I was using the devices (in Scope, not SDK).
Translation below:
Entrées = inputs
Retours = returns
plug-ins for scope
SpaceF website
SC website
