1- you can directly connect the outputs to some active external speakers. I have 4 of them attached to the A16.
2- zlink dest is the output interface, who's only target I know about, is an A16u. Maybe I don't get your question right..
3- I suspect, you have an A16ultra, as you mentioned zlink. A16ultra is 12V/5a, while the A16 is 18V.
You don't damange anything with your psu, but you might inject noise to the analog signal, as laptop psu have a higher ripple, compared to psu for audio applications.
A16U simple questions
Re: A16 ultra simple question
- sunmachine
No, the routing within the A16 is fix. Depending of what you have in mind, this might be possible in SCOPE's Routing Window.GordonGekko wrote: Sun Feb 18, 2024 4:21 am 2 - Is there a way to route zlink a dest 1and 2 to something other than a16 analog a 1 and 2 out?
Some matrix maybe?
- Bud Weiser
according to the manual, it´s 12 VAC, 1.5A !!!
I use 2 A16U and one of the PSUs is exactly this,- the other is a (norway) MASCOT PSU 12 VAC, 1.6A.
Both work like a charme w/ Z-Link and a 3-card PCI system as well as XITE-1 (w/ a blackface one)
