Mix to AB (Mono)
spacef
Mix to AB (Mono)
Post by spacef »
I use this to send various mono signals to external mono effects (such as spring reverb tanks ;-) )
Not a router/merger. Just 2 x Mix3 modules into 1 device. with vu-meters, to save space in the project window.
No midi or presets.
A more sophisticated version can be found here: https://www.forums.scopeusers.com/viewt ... 33#p356733
Mix-to-AB.zip
(49.98 KiB) Downloaded 503 times
plug-ins for scope
SpaceF website
SC website
spacef
Re: Mix to AB (Mono)
Post by spacef »
UPDATED with text input to label destinations, and preset to save all settings. Also, project module renamed mixAB to save space.
The device file has the same name as before, so if you overwrite previous version it will load in your projects with the new features (in case you have used it).
MixToAB.zip
(42.64 KiB) Downloaded 549 times
plug-ins for scope
SpaceF website
SC website
t_tangent
Post by t_tangent »
Thanks Mehdi,
Very useful :)
spacef
Post by spacef »
There is a more sophisticated version here: https://www.forums.scopeusers.com/viewt ... 33#p356733
This version is still good to stay simple and save resources when they are needed.
plug-ins for scope
SpaceF website
SC website
