It was my birthday recently. So going to treat myself to a 3d party device for my Xite-1.
Was thinking to get Aderns xor…
Does it run nice on Xite?
Does XOR run nice on Xite-1 ?
Re: Does XOR run nice on Xite-1 ?
Yes, it does. I use it in many projects, it's a cool synth.
Curious if you use it for mainly mono synth lines? How many voices do you typically get on the Xite before SAT errors?nebelfuerst wrote: Fri Feb 02, 2024 11:57 am Yes, it does. I use it in many projects, it's a cool synth.
It is a great sounding synth no doubt.
Personally I was actually thinking of transferring the license to my PCI computer since it seems to suffer the same SAT restrictions on the Xite as the ZARG synths with regards to polyphony.
and HB also Liquid EDGE.
The Xor-sounds I use are used for baselines, thus I just used mono since. I never evaluated the polyphony limit, yet.
Thanks for the answers guys and the bday wishes.
Good to know it runs fine.
So when I installed xor… it wasn’t making sound right, was thinking it was broken.
My mistake was replacing and installing the dsp files in the scope Xite app/dsp folder that came with xor.. DONT DO THAT. The dsp files that come with xor shouldn’t be included as they are out of date.
Anyhow, synth sounds great.
Do they replace stock DSPs or other Adern ones?
Seemed like stock ones to me.
I restored the ones that i copied over from a back up of the scope Xite folder I have.
I'll check my install shortly, thanks.
