A16
Chilliman
A16
Post by Chilliman »
Managed to snag an A16 ultra nearby. Pick it up tomorrow. Noticed it had Z-link. Was that on more than a Luna? Every card I've ever seen that is a pulsar or higher has been a breakout cable and a pair of toslink optical ports, or a blank plate.
Most things that used FireWire type connections were pretty good. Wondered if there were io plates with z-link out there.
And something else. Downloaded the manual. There was a section about using balanced cables (TRS) and if you had to use TS mono cables, to only push them part of the way in. Thought I must be reading that wrong. Do I really have to swerve mono/unbalanced/TS cables on it?
Re: A16
yes, there were z-link i/o plates.
z-link is not firewire, it only uses a firewire cable. connecting to firewire+damage.
make the proper cables to go from balanced to unbalaced. btw-the impedance and level of balanced and unbalanced are different....
Re: A16
garyb wrote: Sun Oct 29, 2023 10:17 am
supplement ...
Edit:
Sorry, wrong pic. :(
Chilliman
Re: A16
Post by Chilliman »
garyb wrote: Sun Oct 29, 2023 10:17 am yes, there were z-link i/o plates.
Yeah, I get that. It's clearly not FireWire. It's z-link. I've had a couple of pieces that used their own proprietary link over the cable format. They were good. RME being one.
Yeah, cables is basic stuff.
What I'm asking is, would mono cables actually damage the unit?
If so I'll have to label it up to make sure nobody else tries.
How is it for clocking? I want it to be a slave.
Re: A16
https://www.ranecommercial.com/kb_artic ... ticle=2107
z-link has one option for sync, slave.
Chilliman
Re: A16
Post by Chilliman »
I don't have z-link.
My cards are classic io.
Re: A16
Bud Weiser wrote: Sun Oct 29, 2023 11:33 am
supplement ...
that cable will not work because positive and negative polarity will cancel each other out if „mixed“ on a single tip. :-?
t_tangent
Re: A16
Post by t_tangent »
This manual might be of use to the OP
https://www.strumentimusicali.net/manua ... RA_ENG.pdf
Chilliman
Re: A16
Post by Chilliman »
Thanks for that 👍
Re: A16
Would like to download the PDF, but the link doesn´t work anymore.
Tried to print entire site and tried to make a screenshot and convert to PDF,- but bad and unusable results unfortunately. :-?
t_tangent
Re: A16
Post by t_tangent »
Bud Weiser wrote: Tue Oct 31, 2023 2:54 am
8)
Bud, I am pretty sure I have that Rane pdf somewhere, but I’ll have to find it on the weekend as I won’t have access to it for a few days. Send me a pm reminder on Saturday and I will have a look then
djmicron
Re: A16
Post by djmicron »
8)
try it from this link:
https://www.ranecommercial.com/legacy/p ... ection.pdf
Re: A16
djmicron wrote: Tue Oct 31, 2023 11:11 am
thank you djM,- that worked !
Re: A16
t_tangent wrote: Tue Oct 31, 2023 5:38 am
tangent,- thx a lot for the offer ! 8)
But meanwhile I´m covered (see above).
Have nice days and a bit more free time on upcoming weekend now. :wink:
best
t_tangent
Re: A16
Post by t_tangent »
Ah ok, cool. :)
And thanks, same for you :)
