This is a track that uses
- Neodyne for bass (heavily equalized)
- KrOn to control an analog sequence (one that sounds a bit like flute, at 2mn40 or so, it also uses the EGs/VCAs and delayer, eventhough in the course of mixing i've cut the samples and rebuilt the melody a bit in the DAW).
- B2003 for an organ doubling (into guitar sim vsts to distort it)
- Echo 4 and Tri-delay for delay effects (and you can hear bits of a new delay on a piano at 2mn54, and it does the "woosh" effect at 4mn22)
- the melodic synth at 1:40 and the solo that follows are spacef oscillators into Pigment (Some BB2 oscillators sampled, or may be the Magma collection, not 100% sure right now which is which but you get the idea).
I hope you like it...
The video is images from midjourney animated in runway.ml (it's good for abstract psychedelic stuff, and might wortk sometimes on other subjects)
 https://www.youtube.com/watch?v=jSoZ0MreALE
							SHIMBAYA DUB
SHIMBAYA DUB
				- SHIMBAYA-MANTRA-small.jpg (44.69 KiB) Viewed 14808 times
