can I set the connection defaults for a loaded device ?
nebelfuerst
Post by nebelfuerst »
Bad weather + vacationtime made me hear through flexor's "ready to play library".
Unfortuately for each patch, a new modular2 is being loaded, which I have to connect to midi-input and audio output each time by hand.
Scope did connect to Xite-Midi-Source by default, but I need to use sequencer-source.
Is there a way to define, which default connections are used on device load ?
t_tangent
Re: can I set the connection defaults for a loaded device ?
Post by t_tangent »
Go to Scope Settings then click on Routing tab and select Connect Instruments / Effects to Sequencer Source. Hopefully that will sort you out :)
nebelfuerst
8) ThnX !
It's the first time after 25 year, that I entered that settings-menu
