Adobe Audition 2023 tilts during start-up
Matti
Post by Matti »
Hi, I have a powerful DELL Win10 PC and Sonic Pulsar II card installed on the PCI bus and SONIC v7. I have used Adobe Audition 2022 and 2023 applications as software. In June, Audition 2023 came with update version V23.5, after which the program stopped working. During start-up, the machine completely tilts and needs to be restarted. Adobe Audition's professional service investigated the matter and concluded that:
the problem occurs when the program tries to load the required startup information, and the problem is caused by SCOPE? Does anyone have experience or knowledge of something similar?
Luckily I haven't uninstalled Audition 2022 from my machine
And I can still work on it, but 2023 should be made to work anyway. I haven't yet received a response from Audobe Audition developers to the survey I sent a couple of weeks ago? -Matti
Re: Adobe Audition 2023 tilts during start-up
The changes they made to querying the ASIO driver will not work with Scope. Many of us use a separate PC attached via ADAT & etc for applications that have this issue. Scope 8 is also in beta and will address this in time.
try running Audition in win8 compatibility mode.
fidox
Post by fidox »
garyb wrote: Fri Aug 04, 2023 6:15 am try running Audition in win8 compatibility mode.
Was just thinking the same thing.
Like I did on one of mine computers, Win11, after Cubase Elements update, from 9.5 to 12, SCOPE (5.1)/ASIO was not recognized anymore, so I tried with "compatibility" mode and now works fine on that machine.
On machine with win10, Scope 7 didn't have any problems so far with updated programs. (Sound Forge, Cubase ... ).
Matti
Post by Matti »
And how can I running Audition in win8 compatbility mode? -Matti
fidox
Post by fidox »
On Shortcut right click - properties - compabitility mode.
Matti
Post by Matti »
Hi, I dont find the shortcut to SCOPE 5 properties?
-MATTI
fidox
Post by fidox »
When I install Scope software, shotcut is always automatically created.
You can always create your own shortcut for any program you want to.
Right click on desktop and select create shortcut, then browse to Scope folder, where Scope.exe is located.
not Scope 5, but audition....
you have Scope 7, right? Scope 5 in the picture was just an example.
fidox
Post by fidox »
garyb wrote: Thu Sep 07, 2023 6:23 am not Scope 5, but audition....
yea, you are right, scope 5 was just example, on Audition's shortcut 👍🙂
