Midi clock to Scope environment internally ?
dip333
Post by dip333 »
Hello sorry to disturb, I try to send midi clock internally in the scope from other sequencer but the midi clock was received with wrong tempo by scope environment, I have tested with some different sequencer (live, cubase, old logic and renoise) the scope environnement can't detect correct tempo ? I have checked with module midi monitor and midi filtred (all others midi data) in the scope environment f8 clock are received but with wrong temp. I haven't any problem, if I send midi clock to external hardware but only for sync in scope environment ?
I forgot some things ?
I use version 32bit version windows 7 and two scope pci with version scope_v7.0.1706_x32_pci_english.
Many thanks for help
All the Best
t_tangent
Re: Midi clock to Scope environment internally ?
Post by t_tangent »
The following link might help you, as it sounds like the same issue I had some time ago.
viewtopic.php?p=333711#p333711
dip333
Post by dip333 »
Problem Solving !
Thanks you M. t_tangent :-)
t_tangent wrote: Thu Jun 01, 2023 12:30 am The following link might help you, as it sounds like the same issue I had some time ago.
Send me this file please (I know I have it but want to associate your exact file with your listed fix).
These things really should be tracked on the parent site, I wish I had more time.
t_tangent
Post by t_tangent »
Will try and remember to look for it later on :)
djmicron
Post by djmicron »
I attached the file for future reference.
MidiclockFix.7z
(2.9 KiB) Downloaded 516 times
t_tangent
Post by t_tangent »
Thanks djm. :)
Yes hopefully that will sort out the OP’s issue
