Problem whit midi scope 5,1
Ciairo
Post by Ciairo »
Hi everyone, I have a problem with scope 5.1 midi connected with reaper asio. The sound is continually interrupted by pops and drops, especially with scope synths. Can anyone help me? Thanks in advance.
mausmuso
Re: Problem whit midi scope 5,1
Post by mausmuso »
Hi There,
I hope you managed to get things setup.
If not you might try some of the tweaks detailed here
https://www.scopeusers.com/ScopeRise/is ... _setup.htm
or here
viewtopic.php?p=351680&hilit=hyperthreading#p351680
regards
maus
JuozasG
Post by JuozasG »
Hi, try to disable in device manager > system devices > high precision event timer (HPET). For me only this helped to fix random pops and clicks.
there are no clicks and pops associated with midi. are the clicks and pops on recordings, or when playing instruments? are you monitoring through the sequencer?
did you do the setup suggestions here?
viewtopic.php?t=31345
Chilliman
Post by Chilliman »
Clicks and pops are usually buffer size related.
