Mixab Mixers
mausmuso
Mixab Mixers
Post by mausmuso »
Its been a little quiet here of late so I thought maybe some of you might be interested in my latest mixers?
There are 4 mixers based on the same basic design.
Each nixer has variations on skins and buss/Aux return set ups.
The 'LP' versions are meant to be low profile to give screen space for othe devices.
The Mix12ab versions allow you to use channels 9, 10, 11 & 12 as channels, busses or auxillary returns.
All the mixers have 'A/B' switches for each channel and a global 'A/B' to switch them all between two mixes.
You can copy 'A' to 'B' or 'B' to 'A' at the channel and/or global levels.
I mostly use the Mix12a/b LP version for stemming final mixes from a DAW.
You can record the whole mix, PreFXs or any of the 12 channels back to your DAW.
The Mix8 a/b version also allows you to send a Bus1 submix to Bus2.
Let me know if you are interested in trying out these mixers and I will upload them.
regards
maus
Mixab Mixers.png (311.04 KiB) Viewed 34726 times
Re: Mixab Mixers
Hi maus. Those mixers look nice. I would definitely like to try them out.
Dan
mausmuso
Re: Mixab Mixers
Post by mausmuso »
yayajohn wrote: Thu Feb 02, 2023 3:08 pm Hi maus. Those mixers look nice. I would definitely like to try them out.
Dan
Thanks Dan
I will upload them individually as its too big a file to upload them as one zip file
maus
mausmuso
Re: Mixab Mixers
Post by mausmuso »
Mix8ab
Mix8ab.zip
(2.24 MiB) Downloaded 637 times
mausmuso
Re: Mixab Mixers
Post by mausmuso »
Mix8ab LP
Mix8ab LP.zip
(1.66 MiB) Downloaded 650 times
mausmuso
Re: Mixab Mixers
Post by mausmuso »
Mix12ab Skin Crawler
Mixab Skin Crawler.zip
(2.4 MiB) Downloaded 657 times
mausmuso
Re: Mixab Mixers
Post by mausmuso »
Mix12ab LP
Mix12ab LP.zip
(2.4 MiB) Downloaded 607 times
Re: Mixab Mixers
Thanks maus they are really great.
mausmuso
Re: Mixab Mixers
Post by mausmuso »
yayajohn wrote: Fri Feb 03, 2023 9:12 am Thanks maus they are really great.
Thanks yaya,
I was aiming to provide options for various working scenarios so one mixer may best suit you over the others.
BTW,
They work fine on my second setup - Pulsar 2 card running Scope 5.1 (Windows 10 32bit).
I maintain this second PC mainly so I can still use the STS samplers and also to test devices on a PCIe card.
Just in passing each channel can be disabled to save on DSP if needed.
regards
maus
Re: Mixab Mixers
Yes, thanks. I also work a second computer on 32bit for the STS and ZARG synths.
These new mixers will definitely come in handy.
btw, I was wondering if you could go back and check one of your older mixers from ~2019?
It's the Matrix Mixer 16X8 v5. Bus 4 and 5 are not showing the correct output nodes.
It'a a super nice mixer and a great addition to your collection.
Dan
mausmuso
Re: Mixab Mixers
Post by mausmuso »
yayajohn wrote: Sun Feb 05, 2023 4:18 am Yes, thanks. I also work a second computer on 32bit for the STS and ZARG synths.
Dan
Thanks Dan
I will go back and have a look at that issue
regards
maus
mausmuso
Re: Mixab Mixers
Post by mausmuso »
mausmuso wrote: Mon Feb 06, 2023 7:23 pm
Dan
Thanks Dan
regards
maus
Hey Dan
I must be missing something here it seems to be right to me.
Can you upload a pic of the issue?
maus
Re: Mixab Mixers
Hi maus, sorry I was away all day yesterday.
Here is a screen shot.
mausmuso
Re: Mixab Mixers
Post by mausmuso »
Ah ok
I will correct that issue
regards
maus
mausmuso
Re: Mixab Mixers
Post by mausmuso »
Updated MatrixMixer168
version 5.1
MatrixMixer168_5_1.zip
(2.65 MiB) Downloaded 759 times
Re: Mixab Mixers
Thanks Maus!
Yogimeister
Re: Mixab Mixers
Post by Yogimeister »
Thanks Mausmuso!
The A/B mixers look nice!
mausmuso
Re: Mixab Mixers
Post by mausmuso »
Yogimeister wrote: Thu Oct 05, 2023 1:22 am Thanks Mausmuso!
Thanks Yogimeister,
There is a 16 channel version I have not uploaded, but can do if there is any interest?
Its the version I use the most as a general mixer and for mastering stems.
regards
maus
guppy
Re: Mixab Mixers
Post by guppy »
Thank you for all your nice plugins maumusmo !
It would be nice if we could have a look to your 16 channel version please, thank you :)
mausmuso
Re: Mixab Mixers
Post by mausmuso »
guppy wrote: Sun Aug 10, 2025 6:30 pm Thank you for all your nice plugins maumusmo !
Hi Guppy,
Here is the Mix 16ab LP, hope it is useful for you.
Regards
maus
Mix16abLP.zip
(3.35 MiB) Downloaded 66 times
