"plop" sound every 3 seconds ? power supply problem ?
alexarmens
Post by alexarmens »
Hi guys, I got a big power supply problem but just want to know if somebody has already have the same,
I'got a "plop sound" every 3 or 4 seconds that occurs even when the xite is not running on PC (I hear it by the phones), I can open my scope V5.1, and see on the first channel on every mixer i use. did someone already get that ? I suppose it's a power problem but I use an AC 12v 3000ma external , the same as the original one .
Re: "plop" sound every 3 seconds ? power supply problem ?
Capacitor somewhere in the chain? Or clock issue, are you syncing to external clock?
alexarmens
the plop occurs only in analog, by the headphones in fact and chained in the mic/di front . the "plop" is not recorded by the asio, strange no???
alexarmens wrote: Tue Nov 08, 2022 10:06 am the plop occurs only in analog, by the headphones in fact and chained in the mic/di front . the "plop" is not recorded by the asio, strange no???
So, the "plop" doesn´t appear on XITE´s balanced analog outs on the rear panel ?
The mic/Di (and phones) connector board is a daughterboard of XITE-1´s mainboard.
When under warranty still, you might need a replacment easy to exchange.
When it´s out of warranty and you have some tech skills (or one of your friends has), open XITE, have a look and investigate.
This board is small and easy to ship as it is relatively easy to install WHEN you or the friend aren´t tech greenhorns.
alexarmens
thx for the reply Bud ! I'll see that with a friend of mine ;)
