PC cleaning, necessary ?
spacef
Post by spacef »
Hi all,
Gonna upgrade to win 10 later this month (yes, I am still on win7)
I will clean the PC internal, removing dust. I was wondering if a spray to clean electronic components is a good thing ?
Like to clean PCIe connectors, sata connectors, and spray everything.
I don't think I've used one of those before.
Link in french but german brand.
eg https://www.amazon.fr/gp/product/B08HH7 ... NB96&psc=1
Thanks !
plug-ins for scope
SpaceF website
SC website
Re: PC cleaning, necessary ?
NO
https://www.amazon.fr/s?k=caig+deoxit&ref=nb_sb_noss_2
Caig De-Oxit 100% for nasty cleanup (badly oxidized, corroded etc).
Caig De-Oxit 5% for normal contacts, there's a Gold 5% version too for Gold contacts.
If you search the forums, you'll find a thread that discusses contact cleaner, Deoxit and something called Stabilant 22 (iirc).
Compressed Air / Argon is good too. No pump based air compressors, they can blow moisture and if a metal tank also corroded metal bits from the inside.
spacef
Post by spacef »
Thanks Valis. I will wait for those. The compressed air stuff is cool, did not know them.
The "dry air" bombs are not ideal indeed, a lot of moisture comes out.
Makes me think I have a mini vacuum cleaner somewhere with a reversible motor, it can blow air out. will look for it and try it to remove dust.
plug-ins for scope
SpaceF website
SC website
be careful with vacuum cleaners. the tips of the cleaning wands tend to build a static charge.
spacef
Post by spacef »
all went fine, I did not need to blow dust.
used a vacuum cleaner with a small brush around the nose, and did not vacuum the motherboard or PCI cards. only the radiators, fans, case...
plug-ins for scope
SpaceF website
SC website
