Sonic Core A16 problem
Joey
Post by Joey »
I have a Sonic Core A16 (the one with an AC power supply)
Sometimes it doesn't start up. Sometimes it turns off.
When I keep the power button pressed, it functions.
Usually after a while I can get it to work, mostly by keeping the power button pressed for a while.
My question: is this a faulty power supply? Or would you guys think there is another problem?
Maybe the power button?
Re: Sonic Core A16 problem
i would think it's the switch...
Joey
Post by Joey »
yes, that is the most probable cause.
it's a bit annoying though, in the middle of a session :(
Joey wrote: Mon Aug 22, 2022 8:54 am yes, that is the most probable cause.
Did you open the A16U case ?
Is it difficult to replace and do you urgently need the original switch as a replacement ?
:wink:
You could as well bridge the switch and instead switch the external PSU (or just plug it in/out for some time)...
Joey
Post by Joey »
I don't much feel like taking it out of the rack for now. So we'll see how it behaves for now. I have considered bridging it, and that's probably what I am going to do at some point. But for now I don't know what switch is used.
The switch from my A16:
Size is 22.6mm x 6.6mm with a kind of integrated plastic spring to keep it in position.
Anything with less than 23mm height and 6.5mm width will fit through the front panel slot.
It‘s a regular light bulb switch, nothing particular.
the ultra has a different switch.
oops, I read a A16 with AC PSU... and thought of the blue one, but re-thinking it... the A16U is also fed by AC :oops: :D
Joey
Post by Joey »
Yeah, that's definitely a different switch. it's a push-in switch (there's probably a technical term for that)
