Mix8 Mixer
mausmuso
Mix8 Mixer
Post by mausmuso »
Hi There
Here is a new mixer I developed.
I built it primarily as a stem mixer, but I also use it as my general default scope mixer.
The mixer itself is common or garden, but does provide an A/B function in each channel to assist in change comparisons.
It can be switched to Mix 4, hiding and turning off Ch 5, 6, 7, and 8 to save on DSP loading.
I use the mixer in 'Mix 4' mode on my second Pulsar II PC, primarily to bring Sample library players across to the main DAW.
You might note in the included PNG pic I have set up a couple of stereo switches so I can record and monitor individual channels from the Mix 8 or coming in from the second PC (via ADAT A). This allows me to record sample player tracks back into the Sequencer as and when needed.
I have included a PDF to help explain the mixer functions (especially the A/B setup).
I hope this mixer is of use to you.
maus
Mix8_Updated_2.zip
(1.6 MiB) Downloaded 387 times
Spielraum
BUG: Mix8 Mixer
Post by Spielraum »
thx for share
check BUG in Record Bus > no signal,
"On/Off" not connected?
mausmuso
Re: BUG: Mix8 Mixer
Post by mausmuso »
Thanks for the feedback, I will fix and repost
regards
maus
mausmuso
Re: Mix8 Mixer
Post by mausmuso »
Updated version - fix Record Bus bug.
Mix8_Updated_2.zip
(1.6 MiB) Downloaded 406 times
regards
maus
Peter Drake
Re: Mix8 Mixer
Post by Peter Drake »
pdf seems to be missing.
mausmuso
Re: Mix8 Mixer
Post by mausmuso »
Sorry about that.
I have uploaded a new zip file.
regards
maus
Re: Mix8 Mixer
Finally got a chance to check this out. Nice little mixer Maus! Great functionality and easy on the resources.
Thanks!
Dan
mausmuso
Re: Mix8 Mixer
Post by mausmuso »
Thanks yaya
I designed it with a couple of goals in mind
- general default mixer and/or stem mixing
- small footprint
- A/B functionality
- Clean simple GUI
regards
maus
