Masterit & C350 blue screen on load. Xite-1 Scope 7 win 10 64bit
Liquid EDGE
Post by Liquid EDGE »
These plug ins crash the system on load.
Has anyone got both these working fine on said set up in title?
(I’ve installed the 64bit files needed, the .sys and the .dev and did not replace the das dsp files already installed with the scope 7 install)
I’ve tried both the 64bit and the Xite .dev files.
C350L works fine, just about to see if there is a masteritL to try.
Re: Masterit & C350 blue screen on load. Xite-1 Scope 7 win 10 64bit
DAS COEFF11 was rendered useless years ago by a Windows 8 KB update.
viewtopic.php?p=339883#p339883
There are light versions of MasterIT and C350L which both work. Or else run Win 7.
Liquid EDGE
dante wrote: Tue Nov 23, 2021 12:14 pm DAS COEFF11 was rendered useless years ago by a Windows 8 KB update.
Thanks for that info. 😊
Do you know what das plug ins relied on coeff11?
As all the free ones they done load fine.
Just those 2 and Legend
Liquid EDGE
That’s lucky then. Not put off getting other das stuff. 😊
